Author Topic: Auxiliary power socket on 21  (Read 1045 times)
Offline Georamage
on: June 10, 2021, 03:36:28 PM
Both my gs and rs had an extra switched power to connect a sat nav and as I understand the s1k also has this under the left panel had a look today and couldnít spot it the only one similar had a connection so does Bmw use it to power the aux socket under passenger seat or any suggestions where to look.
                        Thanks george r
Offline Colberki
  • Bike: 2021 S1000R
  • City / Town: Kuala Lumpur
  • Country: my
Re: Auxiliary power socket on 21
Reply #1 on: July 31, 2021, 02:53:28 AM
There is not one on the S1000 bikes.  Only a USB connector under the piliion seat.  Itís a small hassle when I want to charge the battery.
Offline BS1K
  • Bike: '21 S1000R
  • City / Town: Brisbane, AUS
Reply #2 on: July 31, 2021, 10:14:09 PM
I just routed a 2m USB cable from the port under the pillion seat down through to the battery and under the black plastic around the fuel tank and up where the clutch cable comes out. Easy to install, follow the BMW instructions on installing the sat nav for how to take the panels off.
Offline Hamburg
  • Bike: 2014 Sport
  • City / Town: Oxford
Reply #3 on: July 31, 2021, 10:51:53 PM
 :460:
Offline Georamage
Reply #4 on: August 03, 2021, 10:21:15 PM
*Originally Posted by BS1K [+]
Great idea will use this to run power to tankbag 👍
                George r
Offline Georamage
Reply #5 on: August 03, 2021, 10:50:27 PM
*Originally Posted by Colberki [+]
I found the bmw sat nav power under tank cowl it
Works perfect with adaptor plug to Tom Tom cable works with ignition.
Last Edit: August 03, 2021, 10:50:47 PM by Georamage
Offline Georamage
Reply #6 on: August 05, 2021, 08:21:34 AM
Is there a cable with a waterproof female usb I could leave in place at headstalk like bs1k did and feed into tankbad when fitted with a male usb at other end to plug into pillion charger all the ones I can see have connections to power from battery internet search so far blank
Offline Growler
  • Bike: 2021 S1000R
  • City / Town: Salisbury
Reply #7 on: August 05, 2021, 09:42:28 PM
I have no association with site but am looking at this one https://www.nippynormans.com/f650st-f650cs-f650gs-f650-dakar/bmw-harness-to-female-usb-socket regarding your question in last post, George. Not exactly answering the question but it provides waterproof female USB on ignition-switched line. Trouble is it uses the port under the tank which I think you are already using for TomTom. For me though it is perfect to power a phone on the bars or tankbag leaving the pillion seat port free for anything else.
Offline Georamage
Reply #8 on: August 05, 2021, 09:53:01 PM
Thanks for info I am using plug for sat nav but top tip 👍 very helpful.
                          George r
Offline BS1K
  • Bike: '21 S1000R
Reply #9 on: August 06, 2021, 12:54:52 AM
This looks like what you're after Georamage.
https://www.ebay.com.au/itm/264710687266
But two issues, its only 1m long, might have to get another 1m extension cable and then waterproof the connection yourself, some heat shrink and electrical tap should be enough?
And its the AUS ebay site, so your mileage may vary in the UK.
An alternative idea could be to just get a regular 2m extension cable and just chuck a dust cover on the female end and call it a day.
