Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Vibrating/Rattling Clutch lever  (Read 468 times)
Offline speedydave
  • Bike: 19 s1000r
  • City / Town: Nc, usa
« on: January 13, 2020, 04:06:08 PM »
Good morning,
I picked up a new 2019 s1kr a few weeks ago. Riding has been limited due to winter, but the weather has cooperated some. I have a few buzzy rattles at certain rpm's I am contending with. One was the gas tank cover where the ECU is. I fixed it with some weatherstripping under the center tab.
The next one i'm not sure how to handle. It starts about 6k rpm and gets louder/worse as rpm increases. I isolated it yesterday to the clutch lever. If I pull in the lever slightly it goes away. I checked the bolt and it is tight. I adjusted the cable, and it didn't seem to make a difference.
Has anyone here dealt with a buzzy and noisy clutch lever? How did you fix it?
Thanks
Offline speedydave
  • Bike: 19 s1000r
Re: Vibrating/Rattling Clutch lever
« Reply #1 on: January 20, 2020, 08:28:52 PM »
So the answer is the lever needs to be adjusted to where there is no slack in the clutch cable. At that point I dont like the distance from the handlebar. The solution is new adjustable levers.
Offline MA413
  • Bike: 17S1KR
  • City / Town: New England
« Reply #2 on: January 20, 2020, 09:20:46 PM »
Thats the solution I came up with.   Fitted some Rizomas and problem solved. Watch those micro switch plates if you do the swap as they are a bit feeble.
17S1KR
« Reply #3 on: January 20, 2020, 09:32:31 PM »
There should be 0.5 - 1.0 mm of slack at the clutch lever mount per the owners manual. Adjusting out all of the slack may have an adverse effect on your clutch action.
Offline StandrewsX
« Reply #4 on: January 21, 2020, 07:48:23 AM »
Too much free play also stops the quick shifter working.
