Author Topic: Adaptation reset steps to clear warning lamp  (Read 404 times)
Offline logularjason
  • Bike: 17 s1kr sport
on: June 28, 2021, 05:24:06 AM
Hi all,
Hoping if someone can confirm whether I can clear the warning lamp that I think is triggered by adaptations that are suddenly deemed problematic.  (Codes are shown below).
I have an OBDlink LX dongle, and a full version of the motoscan app.  However, this combination doesn't seem to allow me to clear the "read info trouble codes".
When I enter codes like 3A13D6 into https://bmwfault.codes/ it says to run the service program Reset throttle twistgrip sensor adaptation values.
I cannot find this program, but assume it is the sequence described in these posts:
Simon: https://www.s1000r.co.uk/index.php/topic,8979.0.html
Noggie: https://www.s1000r.co.uk/index.php?topic=5092.0
Now, these sequences haven't worked for me so far, but they differ slightly; e.g.:
- Full throttle vs clutch
- Wait for fan on
So, the big questions are:
- Has anyone been able to clear these faults with motoscan?
- If not, can I reset the adaptations myself via a sequence like above?
- Or, has this only been verified via GS-911?
My fault codes are:
- 3A13D6 throttle grip sensor
- 3A1194 shift-lever sensor
- 3A1183 transmission sensor
- 21200 impermissable operating mode
Re: Adaptation reset steps to clear warning lamp
Reply #1 on: July 17, 2021, 04:55:06 AM
You have a list. Just as an outsider to motoscan, how is your battery, battery connections? I'd check it with a volt meter static and then when you hit the start button. If it drops below 10 volts it is trash.
Reply #2 on: July 18, 2021, 03:38:15 PM
Whoa that's a wild stab in the dark, but thanks for trying.  Battery is fine.
The fault code was cleared when I was scrolling through the bike menus to set the clock.  I held down one of the buttons for a few seconds and the fault cleared - I've been meaning to check the manual to see if this is a documented thing.
