Home
Search
Members Map
Photos Gallery
Login
Register
Forum Rules
Forum Help
Contact Us
27 Feb 21, 21:25 PM
Please
login
or
register
BMW S1000R
Main S1000R Boards
Maintenance, Servicing, and Mechanical
How to repair your ShiftAssist
27 Feb 21, 21:25 PM
BMW S1000XR Forum
Pages: [
1
2
Go Down
Author
Topic: How to repair your ShiftAssist (Read 1118 times)
MachWun
S1000R Member
Topic Author
Bike: '16 s1kr premium
City / Town: Wading River
Country:
on:
January 21, 2021, 08:43:28 PM
Ok, lots of questions on flakey quickshifters, and I have the solution.
First, it's basic operation. The quickshifter is a Variable Reluctance Sensor. It has a variable output, based on the sensed magnetic field. It has 3 wires. Power, ground, and signal. The black plastic portion of the quickshifter is a loop of wire. The loop encircles the rod that extends out of the rear of the quickshifter. As that rod moves in and out of the sensor loop, its output voltage varies. At rest, it produces a 4.5 volt signal. As the quickshifter is extended, the output signal drops to .5 volts. The rate of signal voltage dropping is directly proportional to the rate of shifter actuation. If you bang the shifter, you'll see if go from 4.5 to .5 very fast. If you pussy-foot it, there will be a much longer delay.
The extension rod that comes out of the back of the QS is magnetized in a VERY special way. It must be 'clocked' inside the black plastic loop at exactly the correct position. If it is not clocked in the correct position, the transition from 4.5v to .5v will not be smooth. There will be peaks and valleys, which I will call hash from here on.
This hash is why your QS is not working. The DME sees this hash, and can't determine the position of the QS. Your QS might work for a few minutes, then quit until you restart the bike.
The goal is to find the clocked position of that extension rod, that produces ZERO hash. You will need to loosen both heim joints from the QS assembly. The rear heim is loctited to the extension rod. You must loosen this very carefully.
The downside is to fix this, you will need a labscope, or oscilloscope. Hook it up to the ground, and signal wires as shown in the video. Actuate the QS, and watch the waveform. If you see hash, rotate the extension rod till it's gone. Does not matter which direction you go. Just twist it slowly till you get a smooth waveform. You will then need to rotate the heims so that they are perfectly vertical...WHILE NOT TURNING THE EXTENSION ROD.
Below is a basic video. Excuse the audio, I was jamming out while I got my QS working again.
https://photos.app.goo.gl/VbdMnFHZgwieoYNd6
Once you get the extension rod in the correct position, clear the adaptions for the transmission, and go for a ride!
Logged
rogracer
S1000R Member
Bike: 2015 S1000R
City / Town: Orlando, Florida
Country:
Re: How to repair your ShiftAssist
Reply #1 on:
January 22, 2021, 10:13:06 PM
Good Stuff
I always thought the quickshifter was a load cell that responded to applied force. But you're saying it responds to a bit of axial movement. That seems a bit sloppy to me...like there is a bit of free-play between the shift-lever and transmission (which I've never noticed!) Is the shaft spring-loaded to minimize this and maintain the zero-position?
Last Edit: January 22, 2021, 10:13:41 PM by rogracer
Logged
rogracer
S1000R Member
Bike: 2015 S1000R
Country:
Reply #2 on:
January 25, 2021, 04:10:01 PM
So I futzed around a bit with my QS this morning and I don't see this axial movement that you speak of. It seems pretty stiff and solid without really any free-play
Logged
MachWun
S1000R Member
Topic Author
Country:
Reply #3 on:
January 25, 2021, 04:33:13 PM
Originally Posted by
rogracer
The rear heim joint...It's currently locked to the extension shaft. So twist the heim in relation to the body of the sensor...Also, this is useless without a scoped hooked up and you can see the waveform.
Logged
rogracer
S1000R Member
Bike: 2015 S1000R
Country:
Reply #4 on:
January 25, 2021, 05:02:51 PM
I got you...but just trying to understand what you meant by "As that rod moves in and out of the sensor loop..."
That seems to imply axial movement of the shift-rod.
Logged
MachWun
S1000R Member
Topic Author
Country:
Reply #5 on:
January 26, 2021, 02:16:41 PM
The rod the rear heim joint is attached to, extends about an additional half inch when you load up the quick shifter. Sit on the bike and actuate the shifter while you're looking at it. It's near impossible to extend by hand unless you really are cracking on it.
Logged
rogracer
S1000R Member
Bike: 2015 S1000R
Country:
Reply #6 on:
February 07, 2021, 05:25:19 PM
Right you are MachWun
I went out again and did indeed observe the movement you described. There appears to be an internal preloaded spring that prevents relative movement up to a certain level of applied force, at which point the shaft moves relative to the housing. Since it is this movement that generates the signal, it would seem to imply that the quickshifter will not work unless your foot applies enough force to overcome the preload. I'm shocked at myself for having never noticed this
Logged
MachWun
S1000R Member
Topic Author
Country:
Reply #7 on:
February 07, 2021, 06:07:30 PM
rogracer
It is indeed a strange system, and I believe the spring pre-load is why they call it Shift Assist, and not a quick shifter. It is actually the spring pressure that changes the gear, not your foot. You load up that spring with your foot. At full compression, the bike sees the .5v signal, and cuts spark and fuel. At that point, the spring releases it's energy and clicks the shifter for you.
Logged
MA413
S1000R Pro
Bike: 17’S1KR
City / Town: New England
Country:
Reply #8 on:
February 07, 2021, 08:04:46 PM
Nice work. I learned something new about our bikes and that I’m not the only person that still rocks ODB
Logged
17’S1KR
rogracer
S1000R Member
Bike: 2015 S1000R
Country:
Reply #9 on:
February 08, 2021, 10:23:20 PM
MA413- You have a MY 2017, so you have an up-and-down quickshifter. We were talking about the up-shift only QS on the MY 2015 and 16.....the shaft only extends against the spring preload when upshifting. On downshifts, the shaft and housing are essentially locked together. I'm curious on your MY 2017 if BMW is still using a spring-loaded mechanism (modified so the shaft moves relative to the housing in both directions), or if they went to a load cell.
Logged
Pages: [
1
2
Go Up
A very sunny hello from Brizzle.
New Member Introductions
Alan
Today
at 09:18:02 PM
LED Indicators
Items Wanted
starpower
Today
at 07:01:19 PM
luggage system for S1000R
S1000R - General Chat
bnr54
Today
at 03:26:04 PM
Hello
windyrun
Today
at 11:56:23 AM
Can't turn key in ignition.
beech
Today
at 04:35:03 AM
low speed drop protection
Accessories, Mods and Appearance
SimonUK
Yesterday
at 09:46:10 PM
So, who plans ordering a new 2021 S1000R?
Gnscloz
Yesterday
at 06:41:04 PM
Tail fairings
SimonUK
Yesterday
at 04:56:17 PM
Nice rear...
Items Wanted
Worzel
Yesterday
at 04:50:07 PM
The final stage of my modding journey?
Airsafari87
Yesterday
at 04:47:27 PM
S1000r Brake fluid res
Grumpy Goat
Yesterday
at 03:27:48 PM
Rizoma brake fluid reservoir SOLD
Parts, Accessories & Clothing For Sale
psenior1
Yesterday
at 03:26:40 PM
