Thought you were happy with your set up.
Have read others have also thought about/are in the process of doing similar to their electronic suspension.
What improvements do you hope to gain by the changes?
On the whole I am. Now its set up as best as it can be it is good, and massive improvement on how they come from the dealership.
However.
Because it's improved the pace the bike can be ridden has also increased and I'm starting to find the limitations of the standard suspension, in particular front fork travel. I am finding that the forks are bottoming out, especially under hard braking on track. Ive made all the adjustments I can to mitigate it (including losing weight) but it's still doing it.
So, the move to alternative suspension is my next move.
The thing I'm currently looking at is going for a non DDC set up. I'm lucky that my ECU has been cracked and Crowey has full access to everything in it, so if the non DDC set up does throw up any errors these will be able to be dealt with by him.
