Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: hexcode gs911 service tool  (Read 1926 times)
Re: hexcode gs911 service tool
« Reply #10 on: March 13, 2020, 01:38:08 AM »
Yes.
If you to to the Hexcode home site and then functionality, find the bike click on engine and it breaks it down to details. It is listed there.
« Reply #11 on: March 13, 2020, 09:51:54 AM »
For what it's worth, I'll throw this out there, make sure you do the rest of the first service stuff when you remove the rev limiter.
« Reply #12 on: March 13, 2020, 05:11:13 PM »
For sure, one item that is easy to overlook it re torquing the steering head bearing set up. It is easy to do but pesky. You need to make a socket with teeth to fit one of nuts (the inside one you torque to 15Nm). or buy one for 40 bucks from the dealer. You have to loosen the headlamp assembly and tilt it forward to get to everything. Takes about an hour. The head lamp assembly is held by a couple of screws accessed from the back with the fork tubes almost in the way. a long reach arm on your ratchet and a T25 on the end. A semi wobble extension really helps. This is a regular job every 12 miles. (20thou kilometers)
It is a walk in the park on an RR as access to the handlebars is no problem, no need to push forward the head lamp assembly.
« Last Edit: March 13, 2020, 05:14:33 PM by beech »
Offline clik
  • Country: 00
« Reply #13 on: March 23, 2020, 09:21:36 PM »
Regarding servicing your s1000r bikes  :087:
is there a workshop Manuel or download for the s1000r 2018 up
« Reply #14 on: March 24, 2020, 04:04:01 PM »
The workshop manual I use is the OEM DVD. It is accurate and complete. No information about diagnosing in it just how to do the work. I do not think there is a paper one out there at the moment. You may find on line a down loadable module but I respect the effort the manufacturer put into producing the DVD and appreciate it being available. It is well worth the cost if you compare it against other vehicle maintenance manuals.
« Reply #15 on: March 24, 2020, 08:39:10 PM »
As Beech I use the BMW maintenance DVD, U also have the Haynes Manual for the S1000 series(not specific to the '18, but the majority of it is covered)
Offline clik
  • Country: 00
« Reply #16 on: March 25, 2020, 01:08:24 PM »
thanks guys
