Author Topic: Best battery for 2018 S1000R  (Read 2470 times)
  • Bike: 17S1KR
Re: Best battery for 2018 S1000R
Reply #10 on: February 16, 2020, 07:33:57 PM
I 2nd Yuasa batts.  Very dependable and long lasting if taken care of.
17S1KR
Offline VARRAKK
  • Bike: S1000R '18 (RIP)
  • City / Town: Malm
Reply #11 on: February 17, 2020, 08:25:14 AM
Your tender seems to be damaging your batteries.
Both my Bikes on Yuasa batteries has been left un-tendered since mid September.
And both start just fine with charge on battery.
(Both are stored in a heated garage)
Offline Valvefloat
  • City / Town: Ann Arbor
Reply #12 on: March 02, 2020, 12:00:29 AM
I have found that leaving a Battery Tender connected all winter will result in significant loss of electrolyte. At the same time, not keeping my batteries charged also kills them.
What I do is connect my battery tender to my various batteries on the first of every month. When the Battery Tender reaches float mode, usually no more than one day, I move it to the next battery. When all have been charged, I disconnect and wait for the next month.
Problem solved.
Reply #13 on: September 12, 2020, 07:53:14 PM
There are different abilities/qualities of maintenance chargers. ( do not use the term battery tender because that is a brand name of a unit I do not recommend to use) The good units have serious electronic monitoring systems that detect battery type (not including Lithium) and condition. A good maintenance charger will not trash a battery, a poor unit can cause harm. I suggest using Optimate products, there is another, Xtreme chargers are also good. Include me in the Yuasa battery club also. I think three years is plenty to get out of a battery, after that the odds are against you. If you only ride local what the heck but starting a bike with a failing battery can cause damage. Most of the new bikes have low voltage detection and will not attempt a start but not all have this feature. I don't know if it is part of the S bike electronics and don't intend to find out by trial.
Reply #14 on: September 12, 2020, 09:27:40 PM
I've used an Optimate all winter when riding is limited and all was good.
Reply #15 on: September 12, 2020, 11:10:07 PM
FWIW, the OE BMW battery that I removed from my R as a preventative action (as mentioned earlier in this thread) sat at the back of my garage for the last 3 years. The battery in my quad bike died about a month ago and so I thought Id dig out the OE BMW battery and give it a go. It took a charge from my Optimate without any issues and has been powering the quad bike perfectly happily since.
Reply #16 on: September 13, 2020, 10:08:11 PM
I have a specific question for Yuasa users. I have a 2017 S1000R and am going to get a new battery. I have forgotten what I put in my old 2015 bike which I sold. I look around and the YTZ10S comes up. It is 1/2" (12mm) shorter than the stock battery. Is this the one you fellows are using? The stock OEM battery measures 5 11/16"  (144mm) wide, 3 3/16" (80mm) wide and 4 1/8" (105mm) high. The YTZ10S is a half inch shorter and about the same dimensions otherwise. This battery comes pre filled. I prefer the fill it your self version but that is okay.
Reply #17 on: October 05, 2020, 09:28:56 PM
Here is the one full height I found. And it comes with the acid separate which I like.
Yuasa YUAM329BS YTX9-BS
#18
Offline DRoss
  • Bike: s1000r, fz1
  • City / Town: Mariposa, Ca
Reply #18 on: October 21, 2020, 01:54:44 AM
Only 135 CCA vs 195 CCA for theYTZ10S also less ah. It is cheaper and lighter though.
