Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Heated grip failure  (Read 269 times)
Offline razz
Heated grip failure
« on: February 22, 2019, 10:35:15 AM »
2016 S1000R...
Whilst out for a ride last weekend with the heated grips on, I noticed my right had was getting cold.  On inspection I found that the throttle grip was stone-cold whilst the clutch grip was toasty.
I guess that the heated grip has failed.  Has anyone else had this?  Is there anything I should check before I head off to the dealer to order a new one?  Are they easy to fit, or best left to the dealer?
Re: Heated grip failure
« Reply #1 on: February 22, 2019, 12:44:57 PM »
They are pretty easy to fit, though you will need a small torx(8 or 9) to remove the bottom of the switch housing to be able to unplug the heated grip adn a big torx(45?) to take the bar end off. It should not take a dealer tech more than 15 minutes.
Offline starpower
  • Bike: S1KR, ZeroS
  • City / Town: Potter Valley
« Reply #2 on: February 22, 2019, 06:01:39 PM »
Thats going to be a pricey part! I would explore a repair, likely a loose or broken wire/connection. Certainly not for everyone as it can be delicate but you have nothing to lose in trying. Heated gloves are likely much cheaper and work on all bikes!
"The most beautiful things in the world are those from which all excess weight has been eliminated" - Henry Ford I, 1893
