Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Red Coding plug... Smarts or just a jumper?  (Read 1255 times)
Offline samgab
  • Country: nz
  • Bike: 2018 S1000R
  • City / Town: Auckland
« on: January 17, 2019, 05:59:57 AM »
I suspect that the red so-called "coding plug" is really just a jumper which connects those two wires together, which then tells the ECU that the coding plug is installed, so it can unlock the extra modes; dynamic etc.
Does anyone know for a fact that this is incorrect? ie, are there any active components inside that red plug, or is it just a dumb jumper?
I could find out by removing the coding plug and jumpering the wires to see if the bike still thinks the coding plug is installed, but I don't want to risk my warranty in case I'm wrong.
Has anyone out there cut one open to see what's inside?
Re: Red Coding plug... Smarts or just a jumper?
« Reply #1 on: January 19, 2019, 05:22:52 PM »
For 25$ you could be the first!
12 52 7 727 856    CODING PLUG
I think you and I are on the same page, it probably is a jumper.
« Reply #2 on: January 19, 2019, 10:16:17 PM »
So I removed my coding plug and measured the resistance pin to pin via a fluke meter. Zero ohms. Seems like a jumper to me.
Offline samgab
  • Country: nz
  • Bike: 2018 S1000R
« Reply #3 on: January 19, 2019, 10:44:50 PM »
Yeah, sounds about right. No need for it to be anything more as all the smarts are in the ECU. But I'm still not brave enough to jumper it to test. No need to, I'm just curious...
Offline jlewis2524
  • City / Town: Manheim
« Reply #4 on: March 11, 2019, 02:23:09 AM »
I actually did jump it awhile ago as I purchased my s1k without the plug. It has been completely fine for 4 months of riding last season. Tested the wire to make sure it didn't get hot either and all checks out. Jump that bad boi  :008:
Offline samgab
  • Country: nz
  • Bike: 2018 S1000R
« Reply #5 on: March 11, 2019, 04:44:26 AM »
*Originally Posted by jlewis2524 [+]
Oh wow, and that enabled the dynamic mode etc?
Offline jlewis2524
« Reply #6 on: March 30, 2019, 02:17:03 AM »
Sorry for the late reply  :008: It did. Dynamic Pro as if i put in the red coding plug. Easy as pie
Offline Pavey
  • City / Town: St Albans
« Reply #7 on: March 30, 2019, 11:12:38 AM »
I'd like to give this a try, but am a bit clueless. Where are the two wires to be connected, and do you simply just join them together (or install a cable between two 'sockets'?
Offline jlewis2524
« Reply #8 on: March 30, 2019, 11:28:12 AM »
Look up the location for the coding plug socket on Google images. It will make sense. If you take your seat off it's just to the right of the hinge point of your gas tank. It should be a little oval black connector. You just pullit it out, pull off the cover, and place a wire from one hole to the other inside. Then reverse the process. I would start the bike after you put it in just to make sure it worked. Do the install with your bike OFF though :001:
Offline samgab
  • Country: nz
  • Bike: 2018 S1000R
« Reply #9 on: March 30, 2019, 11:29:51 AM »
*Originally Posted by Pavey [+]
Here's somebody else's video showing how to do it: Edit: Credit where it's due, I presume this is JLewis'es video, the guy who's also be posting about this? lol.  :028:
« Last Edit: March 30, 2019, 11:31:46 AM by samgab »
