Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Garage turned off service light - 2 weeks later it came on again  (Read 560 times)
Offline Scottg132
  • Bike: 2015 BMW S1000R
Just wondering of anyone has experienced the same issue, i recently took my bike to the garage to get my service light turned off, it was fine for about 2 weeks with the light off everything on the dash was back to normal. However i went to go into work about 2 weeks from turning it off and it had come back on with the orange service light and the "SERVICE" indicator.
Any ideas?
Thanks
Re: Garage turned off service light - 2 weeks later it came on again
« Reply #1 on: January 07, 2019, 12:45:22 PM »
BMW has 2 service 'types' - mileage based and time based(annual). My first thought would be that the 'garage' only reset one of those reminders.
Offline Scottg132
« Reply #2 on: January 07, 2019, 12:49:57 PM »
Im not sure as they told me they set the distance back to 4k miles and when I start the bike it comes up with October 2019
Offline Alan
  • City / Town: BRISTOL
« Reply #3 on: January 07, 2019, 04:42:42 PM »
Could it be MOT reminder.  Don't know much about the bike as I have only just got it but I have been driving BMW cars for 15 years and they have several service items that are monitored including MOT, brake fluid, brake pads, spark plugs as well as the usual oil change.  On the cars you can go into a service menu to find out what is causing the service reminder, don't know if the bike has the same function.
Offline Scottg132
« Reply #4 on: January 07, 2019, 04:57:10 PM »
Yeh I will look into it I know the guy well at the garage and should be able to go through it with him. Might just need another reset for a different reason.
Thanks for help  :152:
Offline Alan
« Reply #5 on: January 07, 2019, 05:31:24 PM »
As it is showing October 2019 as the service date, could it be that the date is set wrong?  This is from the owners handbook
If the service-due indicator appears more than a month before the service date, the date saved in the instrument cluster must be adjusted. This situation can occur if the battery was disconnected or a prolonged period of time.
If you want to have the date set consult a specialist workshop, preferably an authorised BMW Motorrad dealer.
Offline Enzio
  • City / Town: Pretoria
« Reply #6 on: January 09, 2019, 06:14:29 AM »
This is the likely answer.
I have done an oil change over December and reset mine with the MotoScan app - it gives you both options: you can specify the mileage reminder distance as per your needs or a date. I suspect since you get a date reminder on the cluster they forgot to add a year to the time-based reminder.
I got nothing.....
