Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: rear preload - screwing on DDC model  (Read 1149 times)
Offline frank3
  • Bike: 2018 s1000r
« on: November 17, 2018, 07:26:43 AM »
Hi,
i wanted to adjusted the sag on my bike with DDC, but when i got to adjusting the preload on the rear this is what i found:
- Factory default setting is preload set all the way to the left (fully anticlockwise) - Is this really factory default?
- to increase preload i need to dial the adjusted to the right.  I decided to screw it all the way to see how many turns were available.    It just kept screwing to the right.  I counted 20 turns before i gave up.   Is this normal or do i have a problem?
regards,
frank
Offline Toolman
  • City / Town: West Sussex
Re: rear preload - screwing on DDC model
« Reply #1 on: November 17, 2018, 11:20:53 AM »
All the way out sounds right to me, that's what I've had before, and yes I didn't count the number of turns in, but it's quite a few! Definitely worth getting right.
« Reply #2 on: November 17, 2018, 12:09:00 PM »
Yep, sounds right on both counts!
Offline frank3
  • Bike: 2018 s1000r
« Reply #3 on: November 17, 2018, 10:01:28 PM »
thanks for your responses.   But can someone tell me how many turns are there to the right (increasing preload) to reach maximum?   Like i said i counted 20 full turns before I stopped thinking this is not normal.
thank-you.
Offline Toolman
« Reply #4 on: November 18, 2018, 06:11:10 PM »
Murphys law says there's probably 21 turns! I never counted how many, but there's certainly quite a few. I'd just keep going until it's correct for your weight.
Offline andrewbrandon19
  • City / Town: Yorktown, VA
« Reply #5 on: December 02, 2018, 09:04:42 PM »
My fat arse maxed out the preload (it wont turn past a certain point when you get it at max) then backed it off half a turn turn.  I was ~245 pounds at the time and the max preload is for a rider at something like 200-210 pounds i think
2015 BMW S1000R  -  The DD
2014 Toyota Taco  -  The "its raining" or "its under 30F out"
2013 Harley Davidson 883 Sportster SOLD
2006 Pontiac GTO  SOLD
1995 Pontiac Firebird  SOLD
Online Meguerra
  • Bike: 2016 BMW S1000R
  • City / Town: Temecula
« Reply #6 on: December 02, 2018, 10:34:22 PM »
 I weight in at 250lbs and have my preload maxed out on both ends. The front feels softer then the rear. Ordered the Wilbers Suspension  9,5 N/mm  forks springs and having a custom spring made for the rear shock by Cannon RaceCraft Inc. to match the stiffer fork springs as I could not find a source for stiffer shock springs for the s1kr. Hoping this will get me in spec sag wise and maintain all the DDC functions.
https://www.wilbers-shop.de/en/Motorcycle/BMW/S-1000-R-K10-2R10/?year=2016
http://www.cannonracecraft.com/
