Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: IAT relocation.  (Read 1891 times)
Offline stever1
  • Bike: s1000r sport
  • City / Town: scotland
IAT relocation.
« on: November 16, 2018, 10:53:02 PM »
Hello everyone.
Has anyone fitted a IAT relocation kit, and did you think it helps?
I have seen it done on the double R.
Many thanks.
Online CrazyBiker
  • Bike: S1R, S1RR
Re: IAT relocation.
« Reply #1 on: November 17, 2018, 12:20:03 AM »
Going to make my own. Have sourced all the connectors. Will make some extra harnesses
2014 S1000R Premium White
Akra GP Slip On|Ohlins Damper|Ermax pan|Tecbike CAT|Bestem Fender|V-stream screen|Wunderlich Seat|360+R&G LED signals|R&G+Puig Protection
Brocks CT Full System|GPR Damper|Elka Stg3|Sato rearsets|Bestem Cowl|Sargent Seat|Puig Screen|Woodcraft+GB protection|MD signals
H&B panniers on both
Re: IAT relocation.
« Reply #2 on: November 17, 2018, 01:32:35 AM »
I had it on my R and moved it over to my XR. not sure if you are going to 'notice' a difference, but the reason for it makes sense to me as there is a lot of heat soak in the S1000 series.
Offline stanksbeamen
  • City / Town: Honolulu
Re: IAT relocation.
« Reply #3 on: November 17, 2018, 05:35:52 PM »
I did some searching here a while back and found this thread. Looked into what AndyNJ did and tried to consolidate more information in the thread. I have yet to do it but its on my things to do list.  :745:
https://www.s1000r.co.uk/index.php/topic,6407.msg72272.html#msg72272
2017 S1000R
1997 E36 M3
Offline stever1
IAT sensor relocated.
« Reply #4 on: November 17, 2018, 11:23:12 PM »
HI to everyone.
Went and relocated the IAT sensor today.
I did not want to make any holes in the nose plastics.
So i made up a alloy bracket and shaped it like a  square  U  shape and fitted it in to the frame/headstock.
The steering damper has a bolt to locate it on the frame/headstock. So by fitting a longer bolt i was able to locate the bracket inside the frame /headstock. A washer and lock nut secures the bracket on the longer bolt. I turned the bracket side on to prevent loss of air flow. A washer was required to give a secure fit to the bracket and the IAT. Fit the sensor with washer in to the bracket followed by the o ring to secure it all. Tie wraps were used to tidy up the wires.
I hope this helps if you want to give it a try.
Offline kerlow66
  • City / Town: LOS ANGELES
Re: IAT relocation.
« Reply #5 on: November 18, 2018, 02:35:33 AM »
Just did mine last week as well got a Ebay oem bosch item way cheaper than bren,Anyways install is pretty straight forward and drilled it right dead center of the nose and used of all things a marker cap to plug the original IAT location.3rd picture was after i spliced the extra plug.
« Last Edit: November 18, 2018, 02:40:22 AM by kerlow66 »
Re: IAT relocation.
« Reply #6 on: November 18, 2018, 05:40:04 PM »
Kerlow how secure is that marker cap? Im assuming it was a snug fit but did it click in or anything?
2017 S1000R
1997 E36 M3
Offline kerlow66
Re: IAT relocation.
« Reply #7 on: November 18, 2018, 05:48:59 PM »
*Originally Posted by stanksbeamen [+]
Cap is super secured you can't pull it out with your hands👌
Online CrazyBiker
  • Bike: S1R, S1RR
Re: IAT relocation.
« Reply #8 on: November 18, 2018, 06:10:49 PM »
Wasted a marker? Just get a few from HD man...
Online CrazyBiker
  • Bike: S1R, S1RR
Re: IAT relocation.
« Reply #9 on: April 16, 2019, 12:57:27 AM »
Getting the hole right was tough as I didn't have the right hole saw size in my stepped drill bit. Plus doing it on the bike made it tough to test how much exact hole size is needed. So I ended up removing the headlight bracket and using a grommet to keep it. So vibrations won't loosen it when mounted like the pictures above by @kerlow66
My own harness. When I find some time I will make a bunch of these. 4ft is too much but I think 3ft should be more than enough.
« Last Edit: April 16, 2019, 12:58:42 AM by CrazyBiker »
