Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Will the Yoshimura Alpha-T for 17/18 S1000RR fit on the 17/18 S1000R?  (Read 1450 times)
Offline BmwHarleyTriumph
  • Country: ph
  • Bike: S1000R 2018
  • City / Town: Metro Manila
Good day to all.
Will they fit? Confused, I see this slip-on described as for 17/18 S1000RR/R in some sites/articles, but Yoshimura says to me via email that they're not sure if it will fit.
Any info is highly appreciated.
Cheers
Offline MeloS1000r
  • City / Town: Coimbra
Re: Will the Yoshimura Alpha-T for 17/18 S1000RR fit on the 17/18 S1000R?
« Reply #1 on: October 27, 2018, 10:40:29 AM »
S1000RR and S1000R >2017 exhausts although similar, are not the same.
Slip ons have the same size for the bigger pipe, but the smaller one, has different length.
I am sure it is possible to make it work, but it could be necessary to cut a bit the S1000RR slip on (small pipe)
« Reply #2 on: October 27, 2018, 11:44:49 AM »
Worst case scenario, you could just buy a set of RR headers, I guess.
  • Country: ph
  • Bike: S1000R 2018
« Reply #3 on: October 29, 2018, 05:26:43 AM »
*Originally Posted by MeloS1000r [+]
How about the hanger? Is it in the same location by the footpeg? The longer smaller pipe is workable, but the hanger would be more difficult to relocate
  • Country: ph
  • Bike: S1000R 2018
« Reply #4 on: October 29, 2018, 05:27:46 AM »
Already have Akra headers. So wish the Yoshimura slip-ons would fit
Offline stever1
  • Bike: s1000r sport
  • City / Town: scotland
« Reply #5 on: November 18, 2018, 10:13:37 PM »
Hello.
I use a double r exhaust link pipe on my 2018 s1000r.
The singe and double r models have the same bore size on both the smaller and larger pipes.
But the double r smaller pipe is longer and will foul on the small bracket welded on the smaller pipe.
What I did was to remove the bracket and smooth down both of the welds.
It looks good without the small bracket.
Offline Baldydaz
  • City / Town: Stockport
« Reply #6 on: November 18, 2018, 10:32:37 PM »
*Originally Posted by stever1 [+]
Hello.
Can you post up some pictures bud. I'd like a nice can on mine but there's currently nothing for the R, whereas the RR has some decent choices.
  • Country: ph
  • Bike: S1000R 2018
« Reply #7 on: November 19, 2018, 03:42:05 AM »
Hello.
Thank you very much for this info. But just some clarification.
So an RR slip-on’s smaller pipe would be shorter? Which you need to make longer?
  • Country: ph
  • Bike: S1000R 2018
« Reply #8 on: November 19, 2018, 03:59:17 AM »
In other words, your RR link pipe’s smaller pipe is longer, so the matching RR slip-on’s smaller pipe is shorter?
Offline stever1
« Reply #9 on: November 20, 2018, 12:53:32 PM »
Hello.
The bore sizes are all the same. Both pipes are the same length on the single R link pipe. But the double R link pipe has a longer small bore pipe.
This is why you need to remove the bracket as it will foul on it. Hope this helps.
