Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: What is the target sag?  (Read 1324 times)
Offline SwiftTone
  • Bike: Ducati SFs
  • City / Town: Bosstown, MA
« on: September 20, 2018, 01:16:32 PM »
According the manual in the "On The Racetrack" section, the ideal sag is 6-10mm front, and 20-24mm rear.
According to Racetech, for the track its 25-30mm front and 25-30mm rear. For the street it should be 30-35mm front and 30-35mm rear.
So what should our target be?
Re: What is the target sag?
« Reply #1 on: September 20, 2018, 01:31:11 PM »
If you have a DDC bike I would go with the BMW manual. BMW uses 'Rider' SAG. I am guessing the Racetech is quoting total SAG.
Offline SwiftTone
  • Bike: Ducati SFs
« Reply #2 on: September 20, 2018, 03:40:47 PM »
According to RaceTech's article, they use Rider Sag aka Rider Sag.
Also note; BMW sag settings are listed in the "On The Track" section of the manual.
I'm 190lbs/86kg fully geared. I haven't set sag yet but hopefully I'm in the spring range.
« Reply #3 on: September 20, 2018, 04:27:34 PM »
If you're 190lbs, it's likely you'll be able to get the sag set properly on a DDC bike, anyone heavier is more likely to be out of luck.  (the manual states an 85kg rider i.e. 187lbs)
Offline SwiftTone
  • Bike: Ducati SFs
« Reply #4 on: September 22, 2018, 03:59:58 PM »
So still looking for an answer on this. Should I go with BMW's front 6-10mm and rear 20-24mm, or Racetech's front and rear 30-35mm?
Do you guys feel like BMW's numbers feel too stiff? Those numbers are even stiffer than Racetech's track numbers.
« Reply #5 on: September 22, 2018, 04:27:55 PM »
You did get an answer, follow the manual if you have DDC, use any method you like if you don't have DDC, there is a difference in how BMW calculates sag over what most people would consider the "conventional" way, that's likely why the numbers are so different.
« Last Edit: September 22, 2018, 04:39:38 PM by zombie »
« Reply #6 on: September 22, 2018, 04:35:08 PM »
*Originally Posted by SwiftTone [+]
Preload has no effect on stiffness, youd have to change springs for that.
Offline SwiftTone
  • Bike: Ducati SFs
« Reply #7 on: September 22, 2018, 05:01:57 PM »
*Originally Posted by SimonS1KR [+]
Ok wrong choice of words.
Has anyone topped out the suspension while going over dips in the road?
  • Bike: S1R, S1RR
« Reply #8 on: September 22, 2018, 05:59:38 PM »
I am within BMWs limits but have bottomed mine out mainly due to the god damn crazy front brakes. Alls good though, just run it in normal in the twisites not in soft. Soft is for commuting and freeway jaunts.
2014 S1000R Premium White
Akra GP Slip On|Ohlins Damper|Ermax pan|Tecbike CAT|Bestem Fender|V-stream screen|Wunderlich Seat|360+R&G LED signals|R&G+Puig Protection
2012 S1000RR Premium Motorsport
Brocks CT Full System|GPR Damper|Elka Stg3|Sato rearsets|Bestem Cowl|Sargent Seat|Puig Screen|Woodcraft+GB protection|MD signals
H&B panniers on both
Offline mmorgan
  • Bike: 2018 S1000R
  • City / Town: Las Vegas
« Reply #9 on: November 11, 2018, 05:27:01 PM »
DDC s1000r and 220ish dressed in gear...I was able to get the front 8mm(minimal effort) and the rear 23mm(more work).   Stock settings with my weight were ~13mm different in front/rear.   SAG adjustments were a definite improvement.
