Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Red Angel Eye  (Read 5828 times)
Re: Red Angel Eye
« Reply #20 on: May 19, 2019, 07:55:20 PM »
I must be missing something, did you guys wire it into the running light, or the high beam?
I keep putting the wires into the plug to the running light and when I plug it in all the way, it cuts the wires to the angel eye right off at the plug due to the tight fit.
Re: Red Angel Eye
« Reply #21 on: May 19, 2019, 09:04:46 PM »
Nevermind, took some trial and error but I managed to get it working...  I think I tapped in at a different spot than the pics on the previous page showed tho.  I went to the plug to the daytime running light (in the left hand light housing... low beam?)
Offline Meguerra
  • Bike: 2016 BMW S1000R
  • City / Town: Temecula
Re: Red Angel Eye
« Reply #22 on: May 19, 2019, 09:05:50 PM »
Yes the running light. I put about 1/8 of the bare wire into the small holes on either side of the male connector then jammed the connectors together. It will become very tight and hard to completely lock the connectors together. I just got it as far as I could to the locking point then tested it and taped it up.
Re: Red Angel Eye
« Reply #23 on: May 19, 2019, 10:27:32 PM »
*Originally Posted by Meguerra [+]
Ah, I thought of doing that, but couldn't get the wires to stay in those holes in the side of the connector while I plugged it in... oh well, in the end the result is more or less the same.
  • Bike: S1R|Tuono|Tiger
Re: Red Angel Eye
« Reply #24 on: May 29, 2019, 12:36:46 AM »
They quiet easily stay in when plugged but the main issue is the wires at the LED light connection get pinched and cut between the fairing and headlight easily. We will see how long it lasts. Each LED is only $3-4 bucks and take like 10-15 mins to install.
2016 Tuono V4 1100 Factory
RACE ECU|Arrow Exhaust|RSV4 Bellpan|CF Tank/Tail sliders|Powerbronze Screen|Koso Heated Grips2014 S1000R Premium
Akra Slip On|Ohlins Damper|Ermax,Tecbike Pan|Bestem CF Fender,sliders|V-stream screen|Wunderlich Seat|360 LED signals|H&B panniers
2017 Tiger Explorer XCa
Expedition Cases|ADV protector
Re: Red Angel Eye
« Reply #25 on: May 29, 2019, 12:37:55 AM »
Don't put the plastic sheathing inside. It will splay the connectors and might rip itself. Just put the metal wire through. I should have taken a picture.
Online atomic
  • Country: hr
Re: Red Angel Eye
« Reply #26 on: May 31, 2019, 08:51:25 PM »
Hi everyone! Could you recommend me link on ebay or other store (preferably UK or Europe to avoid long wait) with pure white colour 5000K angel eyes? I bought as seller on ebay stated pure white 6000K but colour is too bluish... I don't want to pile up lot of rings until i found right white shade  :002:
Thanks
Offline cycler
  • City / Town: New York
Re: Red Angel Eye
« Reply #27 on: June 02, 2019, 11:57:35 PM »
*Originally Posted by RonkonkomaRider [+]
Yup!  Loved the look on my 15
Installed with a switch to avoid legal entanglements.
Bought mine on Amazon- $9 for 2.
You installed a switch to turn the angel eye on and off?  What switch did you buy and how did you run the switch so it can be used to turn it on and off?
2016 BMW S1000RR
2016 Ducati 1299 Panigale
2015 BMW S1000R
2011 Superglide custom. 107 build
2010 Streetglide 117 build
Offline cycler
Re: Red Angel Eye
« Reply #28 on: June 02, 2019, 11:59:58 PM »
I just ordered 2 white pairs.  Ill install one on my S1000R and install the other 2 on my S1000RR.  1 will be a back up
2016 BMW S1000RR
2015 BMW S1000R
Offline cycler
Re: Red Angel Eye
« Reply #29 on: June 16, 2019, 06:47:53 AM »
Damn I wish I looked closely at the pics posted with the ring installed.  I have a carbon fascia.  Easy install I must say.  But when I went to put the fascia back on a part of the fascia at 10 and 11 oclock covered it a bit.  I thought thats how the carbon fascia was made and I wound up removing the ring.  I was going to post and ask if anyone else had that issue with the light being covered a bit.  Then I see al the pics on this post and all the light rings are covered in the same spot.  So now back to the garage tomorrow to do the install again lol
2016 BMW S1000RR
2015 BMW S1000R
