Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Red Angel Eye  (Read 2623 times)
Offline Buckybuk
  • Bike: 2016 S1000R
  • City / Town: Sour Lake
Offline joets185
  • Bike: 2018 S1000R
  • City / Town: Hilliard, OH
Re: Red Angel Eye
« Reply #11 on: January 24, 2019, 04:02:22 AM »
Did you tap into the parking/running lights to wire your high beam angel eye?
Offline RonkonkomaRider
  • Wrong Island, NY
  • City / Town: Ronkonkoma
Re: Red Angel Eye
« Reply #12 on: February 20, 2019, 11:34:54 PM »
Yup!  Loved the look on my 15
Installed with a switch to avoid legal entanglements.
Bought mine on Amazon- $9 for 2.
« Last Edit: February 20, 2019, 11:40:15 PM by RonkonkomaRider »
Rob VB
Long Island BMW Riders Club
2015 S1000R
2016 R1200RS
Re: Red Angel Eye
« Reply #13 on: April 03, 2019, 09:06:14 PM »
*Originally Posted by joets185 [+]
It is actually so easy, you don't even need to tap/cut wires. The wires are thin enough to just insert into the connector and close it.
Just did it yesterday and cost only $2.5 for the halo eyes.
Offline cycler
  • City / Town: New York
Re: Red Angel Eye
« Reply #14 on: April 21, 2019, 07:33:50 AM »
Can you PM me step by step on how you did it and what parts to buy and where to buy them?
2016 BMW S1000RR
2016 Ducati 1299 Panigale
2015 BMW S1000R
2011 Superglide custom. 107 build
2010 Streetglide 117 build
Re: Red Angel Eye
« Reply #15 on: April 21, 2019, 08:44:01 AM »
Will just post it here.
  • Buy the 70mm Angel LEDs from ebay. They can be had for around $5-7/pair
  • Remove the front windscreen, outer headlight fairing by first removing the side panels, and then the 3 mounting screws.
  • Remove the parking light male connector from the high beam side that is press fit into the side of the inner fairing. There is a small tab in the fairing mount that you need to press using a small flathead driver to release the connector.
  • Strip the wire leads from the angle eye to expose the metal wire. You just need to strip around an inch for the wire to fit in the female connector
  • Wind the metal wire so that they don't split when inserting in the factory female connector
  • Insert the wires with correct polarity into the female connector. You can test the polarity by turning on the ignition
  • Bend the metal wires over the female connector and insert the male connector over them
  • Assemble everything back as shown above
  • I didn't feel the need to glue the halo ring as it sits snug between the high beam projector and outer fairing
« Last Edit: April 21, 2019, 09:04:27 AM by CrazyBiker »
