Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Some fluid leaking from a cover  (Read 909 times)
Offline cycler
  • City / Town: New York
« on: August 13, 2018, 03:41:21 AM »
Here is a pic of a Trex cover on the bike. The cover is located to the right and above of the water pump. See the bottom right bolt area and bottom left bolt area? I have fluid leaking from those 2 bolt areas. And its spraying on the hose leading to the water pump, on the right outer water pump cover that has a trex protector and on the lower trex oil cover. The bolts are torqued to spec. However i did have to remove the trex cover twice before and i also remover the bolts originally to install the cover and some fluid seeped out. I checked the micro fiche and saw that there was a gasket for the oil cover. Both covers were on the same page on the micro fiche but I didnt see a gasket for the cover that is leaking. I think its the cam cover? There was no name for the cover on the micro fiche either.
Is there a gasket that goes behind my leaking cover which i need to replace? Or is there silicone gasket sealer that i would need to scrape off and replace?
2016 BMW S1000RR
2016 Ducati 1299 Panigale
2015 BMW S1000R
2011 Superglide custom. 107 build
2010 Streetglide 117 build
Online CrazyBiker
Re: Some fluid leaking from a cover
« Reply #1 on: December 27, 2018, 07:48:56 PM »
No one responded but my suspicion is long bolts that have not tightened well. Otherwise if it was not seeping/spraying before, it shouldn't have done so after the case cover install.
Online andrewbrandon19
  • City / Town: Yorktown, VA
« Reply #2 on: December 27, 2018, 08:54:20 PM »
I had an issue with that particular t-rex cover not seating properly no matter what I (or eventually my dealer) did and leaking like that.  You can scrape off the gasket and try resealing it.  It's been awhile but I think I used a tube of silicone gasket material as I don't remember there being a produced gasket for the cover.  I ended up having to toss that one case protector in the end after over torquing and having my dealer retap the threads.  but if you had it on for a while before you removed the bolts then it's probably just the gasket.
« Last Edit: December 27, 2018, 08:55:35 PM by andrewbrandon19 »
2015 BMW S1000R  -  The DD
2014 Toyota Taco  -  The "its raining" or "its under 30F out"
2013 Harley Davidson 883 Sportster SOLD
2006 Pontiac GTO  SOLD
1995 Pontiac Firebird  SOLD
Online CrazyBiker
« Reply #3 on: December 28, 2018, 07:46:04 AM »
Just add a few washers and it should seal.
Offline Funky
« Reply #4 on: December 29, 2018, 08:04:20 AM »
I had the same issue when I fit R&G race covers that were torqued to their spec, I gave them another very small turn and the problem stopped.
Online windyrun
« Reply #5 on: December 29, 2018, 03:16:17 PM »
Not sure if I understand the issue, but I used GBRacing covers since the 1) looked cool  :062:, and 2) you only use a couple of screws to install so its not necessary to remove the engine parts and thus don't need to muck around with gaskets etc.
Online CrazyBiker
« Reply #6 on: December 29, 2018, 08:30:56 PM »
These covers go over, so no question of dealing with gaskets
« Reply #7 on: December 29, 2018, 08:51:03 PM »
they do go over the cover, but you first have to remove 6 of the 8 bolts that hold the cover on and replace them with the supplied longer bolts.  If the gasket material is gonna develop a flaw after multiple heat cycles then that's the time.
« Last Edit: December 29, 2018, 08:52:18 PM by andrewbrandon19 »
