Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: seat height and pre-load  (Read 1170 times)
Offline frank3
  • Bike: 2018 s1000r
« on: June 24, 2018, 10:33:44 AM »
Sorry guys, I am a newbie here and already asking for help.
I am about to buy 2018 s1000r, but find the bike a tad high.
Would like to know i can get seat height lower by 1.5 inch, before i buy.
I can only think of a couple of ways of going about it.
First shave padding from the seat, and second adjust preload (I weight about 87kg with gear on).
Has anyone done any of the above and if so, how much height did it impact?
thank-you
frank
Offline frank3
  • Bike: 2018 s1000r
Re: seat height and pre-load
« Reply #1 on: June 25, 2018, 12:16:40 AM »
Seeing i got no replies, may i ask s different question:
Those of you who have adjusted your pre-load can you please let me know how much was the seat height impacted?
thanking you in advance.
Online nrthrnbkr
« Reply #2 on: June 25, 2018, 09:52:01 AM »
Hello Frank - try a search on the forum - a few have had a similar issue - here's one thread : https://www.s1000r.co.uk/index.php/topic,2075.msg24967.html#msg24967
Adjusting the pre-load might have some effect but that's really for setting up your handling - another solution is to drop the forks slightly - there are lowering link kits for the rear but this other post wasn't sure how it might affect the DDC : https://www.s1000r.co.uk/index.php?topic=1907.0
If you want a more rounded solution it might be worth contacting a suspension shop (they may have done this to R/RRs before).
« Last Edit: June 25, 2018, 09:52:42 AM by nrthrnbkr »
Offline frank3
  • Bike: 2018 s1000r
« Reply #3 on: June 25, 2018, 11:55:21 AM »
thank you for your response nrthrnbkr
frank
Offline StandrewsX
« Reply #4 on: June 26, 2018, 10:07:52 PM »
Hi and welcome although you say it's a tad tall you don't say whether you've ridden one or not. The suspension has next to no movement when not running but rides at considerably varying heights depending on the selected suspension setting giving a lower ride height on the road. What height are you as at 87kg the seat height should be acceptable. I'm not the Jolly Green Giant but have no issues with the seat height. Try riding an Aprilia Tuono!! I wouldn't try a lowering kit as this will effect the handling.
Offline frank3
  • Bike: 2018 s1000r
« Reply #5 on: June 27, 2018, 07:40:56 AM »
thanks StandrewsX,
yes i have ridden a demo.
I am looking at getting around 35mm lower.
I think 20mm can come from trimming the seat and maybe a further 15mm from preload.
I know i need to consider the right sag.
I was hoping someone can provide further input in the above approach.
frank
Online CrazyBiker
« Reply #6 on: June 28, 2018, 03:42:25 PM »
How tall are you and are you a new rider?
Offline frank3
  • Bike: 2018 s1000r
« Reply #7 on: June 29, 2018, 08:02:10 AM »
I have been riding for a while.  I do not have an issue with not being able to get both my feet flat on the ground, excepting when riding in the city.
I am not sure asking for my height will add any additional information that will result in a solution.  I know i need about an inch in height reduction.
Online CrazyBiker
« Reply #8 on: June 29, 2018, 08:12:11 AM »
I have a few friends who are experienced riders and are below 56 and they do ok with tall bikes. Lowering will compromise handling for sure if you are a spirited rider in twisties.
