Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: 2014 BMW S1000R DDC Rebound Set Up  (Read 981 times)
Offline denislavdenchev
  • Bike: BMW S1000R '14
  • City / Town: Amsterdam
« on: May 06, 2018, 12:36:09 PM »
Hi everyone, a couple of week ago I went to the track and my tire wear indicates that I need to adjust the rebound on my bike on both front and back. I know that I can set the compression damping electronically through the DDC settings and the preload manually.
Do you guys know if the rebound can also be adjusted?
Offline Lowrance
  • Bike: S1KR
  • City / Town: So Cal
Re: 2014 BMW S1000R DDC Rebound Set Up
« Reply #1 on: May 06, 2018, 02:08:01 PM »
It cannot be adjusted independently.
It is adjusted somewhat by the ride mode and soft, normal, hard settings you've got selected.
Offline Simonr23
  • City / Town: Adelaide
« Reply #2 on: May 06, 2018, 11:08:54 PM »
Correct. Do you weigh 60-95kgs? If yes, the bikes electronics are quite fine at keeping things at acceptable levels. Look into other reasons why youre having the wear characteristics you have. Temp, surface, throttle/brake application, etc. is preload set correctly? If this isnt, itll slightly throw out the ddc.
