Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Sportrack for S1000R!  (Read 1770 times)
Offline Motomachines
  • Approved Vendor
  • Bike: S1000R White
  • City / Town: Sterling, VA
« on: January 12, 2018, 05:06:15 PM »
Sportbikes may have storage limitations, but with a Hepco & Beck Sportrack, there are more possibilities than ever for mounting luggage. The Sportrack replaces the rear seat, which you probably don't use, and makes it into a sturdy mounting surface. You are able to mount Hepco and Becker soft bags or other luggage as you please! Made from anodized aluminum, the Sportrack is light but strong. Installation is easy and it locks securely to the rear of the bike.
Here is a link to all of the accessories we have available for the S1KR
https://www.motomachines.com/S1000R-14-_c_660.html
Moto Machines
Importer and Distributor for Hepco & Becker and Ermax Products
Offline ts636
  • City / Town: Glasgow
Re: Sportrack for S1000R!
« Reply #1 on: March 27, 2018, 10:48:22 PM »
Would it be possible to mount a Journey top box to this using the universal alu rack?
  • Approved Vendor
« Reply #2 on: April 19, 2018, 05:08:15 PM »
*Originally Posted by ts636 [+]
Yes... well kinda. A couple of the Journey cases have options that include the universal rack. This can be mounted to the Sportrack. A universal Alurack will not mount to a Sportrack. Here is the link to the cases. The Journey 30 could be a good case for a Sportrack.
https://www.motomachines.com/Journey_c_23.html
Moto Machines
Offline ts636
« Reply #3 on: April 20, 2018, 05:00:26 PM »
Thanks for the reply. I already have the Alurack and a Journey TC50 so was hoping there may be some way to make them fit. Looks like it's going to be better to try to sell them and get some new luggage more suited to the BMW.
  • Approved Vendor
« Reply #4 on: April 20, 2018, 05:38:05 PM »
I understand now what you would like to do. Unfortunately, it just would not work on a Sportrack because of the latch on the underside of the case. If you mounted the Alurack on the Sportrack, there would be no clearance for the latch to attach. That is why the cases with universal adapters have a different design. The case has a flat plate that allows the case to slide and click into place. Below are pictures of this system.
Moto Machines
Offline ts636
« Reply #5 on: April 20, 2018, 10:25:02 PM »
Thanks for the pictures, I can see what you mean. Ebay time for the old luggage I think.
Offline ts636
« Reply #6 on: May 10, 2018, 06:22:55 PM »
Sold my old luggage and was going to go ahead with this setup however on reading the pdf instruction sheet for the sportrack it seems to suggest that the universal adapter is not compatible because it would cover the lock for securing the sportrack to the bike. Is this the case?
  • Approved Vendor
« Reply #7 on: May 10, 2018, 06:47:15 PM »
I suppose that is true. If you take a look at the pictures, you can see the lock towards the rear, on the rack. I did not realize that was the case at first. If you cover up the key slot, there would be no way to get it on and off haha. Many of the Sportracks do not have this design, but the S1KR has to have it this way due to the design of the seat mechanism.
Moto Machines
