Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Footpeg mod for comfort and fast easy swap back to stock for trackdays  (Read 2030 times)
Offline busabim
  • Bim Bim Bom
  • Bike: 2015 RED S1000R
  • City / Town: Toronto
Greetings
I have mentioned the Buell peg mod for all those who suffer from hip and knee pain with the stock footpegs. Recently I drilled out the stock footpeg post with a 1/16th bit and drilled a small hole to allow for a cotter pin for easy swap back to stock for track days.
If you dont have access to drill press, take the stock peg off and take it to any machine shop and drill out a 1/16th hole in the band where the circlip lies and add a small cotter clip.
Here is shot of the clip on the buell pegs.
Swapping back and forth is 1 minute a side.
BB
« Last Edit: July 04, 2017, 02:52:18 PM by busabim »
Offline ctr46
  • City / Town: Strmmen
Where did you get the parts? How much did this mod cost?
Thanks
Offline hedonist222
  • Country: ae
  • Bike: R ninet
  • City / Town: Abu Dhabi
I didn't understand what you did but thanks for sharing.
2016 bmw r ninet
2016 bmw s1000r
Former:
2015 KTM 500 EXC 6 Days
Offline busabim
  • Bim Bim Bom
Re: Footpeg mod for comfort and fast easy swap back to stock for trackdays
« Reply #3 on: September 14, 2017, 08:26:37 PM »
*Originally Posted by ctr46 [+]
Thanks
Buell peg mod costs less than a $100 US for the parts ( search for it)
I used the stock BMW pin which I drilled out. The buell lower pegs come with new springs.
BB
Offline Throttle Chopper
  • Bike: 2016 & XR400R
  • City / Town: Anaheim
« Reply #4 on: September 15, 2017, 09:14:55 PM »
I understood what you did, but perhaps a better photo angle of the Buell peg might show how much lower/offset that peg is compared to stock.  You might also want to put a diagram of modification required to the stock peg and a parts list to really make it simple.  :028:
« Reply #5 on: September 19, 2017, 12:23:07 AM »
I think you meant the drilling the cotter pin bolt and not the peg itself.  :001:
Offline boxerkuh
  • Bike: S1000R;K75;R100R
  • City / Town: Carolina's
« Reply #6 on: February 08, 2019, 06:25:05 PM »
Just received the buell jpegs and have a question about the installation. I took the stock pegs off and the pin is loose without the shaft support. I was planning on drilling it out slightly for support and use the rest off the stock hardware. Am I over thinking this? I am not planning on switching back to stock pegs.
Offline pcoburn
  • Bike: '14 S1000R
  • City / Town: Leesburg, VA
« Reply #7 on: February 20, 2019, 04:24:16 PM »
I just did this mod yesterday.  My pegs didn't come with new springs so I re-used the BMW ones.  I used some nylon spacers to adapt the stock pin to the modified Buell pegs.  A few inches of snow on the ground so I haven't had a chance to try them out.  If I'm not happy with them I can switch back in minutes to the stock parts and I'm only out about $40 and an hour of my time.
I used hard nylon spacers to adapt the 8mm pin (close enough to 5/16") to 1/2" on the Buell pegs (drilled out from 7/16").  I couldn't find spacers that went from 5/16" to 7/16" and wanted something a bit more substantial anyway.  At some point I might take the spacers in to my local machine shop to replicate in aluminum but will see how they work first.
