Hi All,
I have for sale a pair of used HP Brake and Clutch Levers ,they are in great condition other than a small nick on bottom side of the clutch lever(which you don't see when on bike) where the brass insert for the locating pin goes as this was somehow jammed and would not release the locating pin ,so it had to be drilled out to release ,Levers work absolutely fine and as they should so no problems.
