Author Topic: Dynamic - Dynamic Pro: Wheelies  (Read 137901 times)
Offline Blue26
  • City / Town: Dublin, CA
on: May 29, 2014, 06:11:53 AM
What is the difference in Dynamic vs. Dynamic Pro modes regarding wheelies ?
Dynamic = lean angle sensor still active
Dynamic Pro = No restrictions
Is that correct ?
Offline Lowrance
  • Bike: S1KR
  • City / Town: So Cal
Re: Dynamic - Dynamic Pro: Wheelies
Reply #1 on: May 29, 2014, 06:19:14 AM
You can wheelie to your hearts content in Dynamic Pro mode.
Just ran through the gears on Monday with the front wheel in the air, set it down in 6th at well over a ton, down shifted and lofted the rear from 70ish to a stop...good fun! Really starting to gel with this bike (even on stock suspension).
Last Edit: May 29, 2014, 06:22:58 AM by Lowrance
Offline Gilly76
  • Bike: R1/MTS1200/S1R
  • City / Town: Stourbridge
Reply #2 on: May 29, 2014, 10:40:34 AM
*Originally Posted by Blue26 [+]
Is that correct ?
Yep.
Dynamic = Small wheelies that the ECU will cut short
Dynamic Pro = Wheelies as long as you can  :152:
Offline MSD3
  • City / Town: Stony Stratford
Reply #3 on: May 29, 2014, 11:14:54 AM
I'm not brave enough to go into dynamic pro mode yet but am venturing into dynamic when the roads are dry. What is the difference between road and dynamic modes in the real world.
S1000R Sport
R Nine T - ordered
Offline Michanga
  • City / Town: belgrade
  • Country: cs
Reply #4 on: May 29, 2014, 12:05:49 PM
go in Dynamic mode and shut down dtc, that will do the job as well...
Offline Flushman
  • City / Town: Chesterfield
Reply #5 on: May 29, 2014, 12:41:29 PM
Hi Guys.
My wheelie skills are next to useless.
If I crack the throttles full open in 1st or 2nd gear in dynamic will the electronic wizardry stop the bike from flipping over and enable me to do a wheelie?
I haven't had the balls to try it yet.
Bikes: S1000R. Z1000SX. Brutale 1090RR. RSVR. Tuono. Sprint ST. KTM RC8. GSXR1000. Aprilia Falco. Fazer 1000. Daytona 650. CBR600.
Offline Gilly76
Reply #6 on: May 29, 2014, 12:47:00 PM
That's the theory....although I've never tried it.
I can only advise that in Dynamic it won't allow prolonged wheelies, don't know how it knows, angle sensors or differential wheel speed?
Offline Lowrance
  • Bike: S1KR
Reply #7 on: May 29, 2014, 01:41:28 PM
In Dynamic mode the front will come up about a foot and a half and stop. You shift it comes down.
Not to try and scare anyone but in Dynamic Pro mode this bike will easily put you on your ass or head (depending which type of wheel stand you are attepting). Impossible to run to redline in either 1st or 2nd gear without flipping the bike over backwards. Will easily lift the front off throttle in 3rd and also in 4th over a slight rise or bump.
Having said that I put mine in DP with 120 miles on the odometer and haven't changed it since. It should be called the "Fun Mode".
Impressive motor.
Offline inspirikus
  • City / Town: Utrecht
Reply #8 on: May 29, 2014, 11:38:49 PM
*Originally Posted by Lowrance [+]
And you saying not to try and scare anyone :) I am still in learning phase of road mode heheh so probably a year before i even dare to enter Dynamic mode...for pro ahh well around 2-3years
Offline Blue26
Reply #9 on: June 01, 2014, 07:19:48 AM
Thanks for all the feedback ...
I'm no 'stunta' but what I can say so far is that 1st is way to low a gear to play wheelies.  With the standard chop the throttle method the front end comes up way too fast.  It reminds me of a big-bore 2 stroke dirt bike.  I think with a bit of practice it will be all good, but newbies be careful for sure.
Big difference from my last bike (gixxer 1K)
