Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Navigation Mount  (Read 9945 times)
Offline spannerz
  • Bike: s1000r sport
Re: Navigation Mount
« Reply #10 on: March 20, 2016, 01:29:09 PM »
*Originally Posted by JohnnyBMWgood [+]
Not entirely true what you say here, BMW has a Navigator Street available which is around the same pricerange as the Garmin Zumo 3XX. As a matter of fact they share same hardware.
Fits directly onto their own centered mount, just as any Garmin will fit this mount.
probably :028: but my son has just bought the central mounted sat nav top of the range 600  that's all im going off!  my garmin came with my bike zumo 550 don't even know how good it is :027:
sk1r
Offline busabim
  • Bim Bim Bom
  • Bike: 2015 RED S1000R
  • City / Town: Toronto
« Reply #11 on: March 20, 2016, 03:34:22 PM »
Here is my Garmin mount-- Techmount silver handlebar mount with RAM Garmin holder dedicated to each GPS.
You may also notice the Rox risers.
View from other side
« Last Edit: March 20, 2016, 03:41:37 PM by busabim »
Offline Shasta McNasty
  • City / Town: Northville, MI
« Reply #12 on: March 20, 2016, 11:31:20 PM »
I have mine mounted in a similar location using RAM mount hardware.  I replaced one of the handlebar bolts with a RAM ball, and then use a 3" extension to hold the Garmin cradle.  I find this location very convenient and it doesn't interfere at all with my tank bag.  Unfortunately it is not quite spring yet in Michigan (despite the calendar!), so my bike is covered up and I can't take a picture at the moment.
Offline nastyb
  • City / Town: Tyne and Wear
« Reply #13 on: March 21, 2016, 04:35:46 PM »
+1 for the SW-Motech mount, ordered mine today 👍
What I'm more concerned about is the issue of the Canbus staying live when the power is connected to the cradle via the Canbus
« Reply #14 on: March 21, 2016, 04:46:19 PM »
*Originally Posted by nastyb [+]
I saw some people had this concern.  It does not happen with my Garmin Zumo 350.  About 10 seconds after shutting the key off, the Garmin displays "external power lost, shutting off in <countdown> seconds".  Then, once the countdown completes the Zumo shuts off.  I then double-checked that there is no power at the Canbus port--even going so far as to check on the diagnostic connector under the pillion seat with an oscilloscope to make sure there was no Canbus power or traffic there.
When I turn the key on again, the Garmin wakes up just like if I had it on a pure ignition-switched hard wire.
Obviously I haven't tested every GPS, but that's why BMW puts this connector there, and they run the BMW-branded Garmins from that port.
Offline spannerz
« Reply #15 on: March 21, 2016, 07:49:22 PM »
*Originally Posted by Shasta McNasty [+]
I have the garmin 550 fitted to mine is that the easiest way to check ? not even fitted it on bike and tried it :012: whats with this canbus problem?
sk1r
« Reply #16 on: March 21, 2016, 08:11:30 PM »
*Originally Posted by spannerz [+]
Short version: don't worry, put your GPS on, ride the bike.   :305:
Long version: some people expressed a concern that plugging something into the OA port might result in an improper shutdown of some electronic modules on the CANbus, which could then lead to a drained battery.  I have never heard any reports that this actually happens, but people are paranoid.
For sure it doesn't happen with my GPS, and I would be very surprised to find that BMW screwed this up.  I think it's an old wives tale.  But if you're worried you can easily verify whether the power is shut off, just by watching your Garmin's display--if it says "external power lost" then the power is shut off!  With more effort, you can verify whether any electronic modules are still talking on CANbus--you're on your own to figure out how (hint: you will need an oscilloscope or some other dedicated electronic test equipment, which most people will not have at home).
Offline nastyb
« Reply #17 on: March 22, 2016, 11:25:43 AM »
The issue is when the ignition has been switched off with the power lead connected and without the SatNav in the cradle I believe. When switching off the ignition the cradle continues to draw power and keeps the CANbus live causing the battery to drain quickly.
When the SatNav is in the cradle when the bike is switched off it works correctly, cutting power via the CANbus.
This is what I've been told by a Motorrad Service technician, they recommended I connect direct to battery, however, another Motorrad Service technician at another dealer says the opposite but says it's hit and miss whether the CANbus power actually works  :155:
« Reply #18 on: March 22, 2016, 11:36:13 AM »
No issues here on either a S1000R or K1300S. GPS on both (Garmin 660) is powered from the Canbus plug, turns on with the ignition, turns off about 60 seconds after turning off the ignition.
« Reply #19 on: March 22, 2016, 02:49:06 PM »
This is exactly how "old wives tales" propagate..."I heard from a guy that there might be a problem...but another guy says exactly the opposite"   :087:
That's why I did a test.  For sure I can't report on all possible configurations, but I did share results on one specific configuration.  Maybe others could try other configurations and in the end we could finally put this concern to rest with actual data.
I can also confirm that I did not see any issue with the GPS out of the cradle either.
It would be very surprising to me if the OA connector--designed to support GPS installation--has such a fundamental design flaw.  It's possible I guess--electronics are notoriously tricky--but seems highly unlikely to me.  I would personally be really interested to hear any first-hand reports of problems!
