Author Topic: Exhaust valve servo removal  (Read 12588 times)
Offline Sub
  • Bike: '15 s1000r
Re: Exhaust valve servo removal
Reply #10 on: July 29, 2015, 01:43:38 PM
ok thanks guys. can u share part info on the decat and db killer please?
Offline jbeez1000
Reply #11 on: July 29, 2015, 09:27:39 PM
I fitted the Austin Racing ARCS de-cat system which requires cutting off your cat and clamping on the AR y-piece in it's place along with the AR carbon can. I also ordered a decibel killer from them which just bolts in to the end of the can itself and can be removed in seconds if needed. Hope this helps !   :002:
Offline IMFA
  • City / Town: Stockholm
Reply #12 on: August 11, 2016, 05:48:41 PM
Does removing the subframe bolt give you more wiggleroom? I cant it removed because the servo motor is hitting a bracket that is attached to the subframe...
Offline Dune19670
  • City / Town: Essex
Reply #13 on: August 11, 2016, 08:31:46 PM
Yes you have to remove the subframe bolt, then the servo motor slides out on a bracket
Offline fUr246
  • Bike: 2019 S1000RR
  • City / Town: St Michael
  • Country: bb
Reply #14 on: July 21, 2020, 10:35:40 PM
Raising this from the dead but I'm wanting to do this mod since I currently just have the cables hanging.
Does removing the servo give an engine check light
Offline Teamgreen2
  • Bike: 2016 S1000R
  • City / Town: Newbury
Reply #15 on: July 22, 2020, 08:20:42 AM
Not if you get a Servo Buddy, I did this recently to my S1k. When removing the servo I had to undo the rear sets and the rear break fluid reservoir such a fiddley job not much wiggle room. This was the one I went for
https://www.ebay.co.uk/itm/BMW-S1000R-S1000XR-All-Years-Healtech-Exhaust-Servo-Eliminator-ESE/323310118831?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Online mad ad
Reply #16 on: July 22, 2020, 08:35:47 AM
You can also remove the cable from the servo unit itself and put the servo unit back in place and it will still think the cables are in place with no dash problems at all. The servo unit is not a sealed unit and comes apart with three screws and you can just pop the cables out like you with the exhaust end and you can put back when ever you want.
Last Edit: July 22, 2020, 08:38:21 AM by mad ad
Reply #17 on: July 31, 2020, 05:29:57 AM
*Originally Posted by tsunami [+]
how much louder does it get when you remove the servo ?
The S100R goes wide open servo baffle when you shift into third gear. So you can use that sound level for your needs. The system helps with low end torque. Unless you are installing a complete header system and fuel management system i see no need to mess with it. You will not get any increase in performance.
Hey, the bike is already highly tuned. You want more HP, buy a RR. You want more noise, then what the heck... Keep in mind many aftermarket systems actually produce less hp.
