Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Low beam shut-off cure... maybe.  (Read 142863 times)
Offline stanksbeamen
  • City / Town: Honolulu
Re: Low beam shut-off cure... maybe.
« Reply #520 on: July 25, 2018, 02:47:02 AM »
Yes, I have both low and high beam HID installed as well as the 'low beam on all the time fix', but I do not think you can use the canbus plug.
pm your e-mail and I can send you instructions on the 'low beam on all the time fix'  that u used with my HID. You will need a 12v relay and some wir.
I'll PM you shortly, thanks for the information and help!  :062:
2017 S1000R
1997 E36 M3
Online CrazyBiker
  • Bike: S1R, S1RR
« Reply #521 on: July 25, 2018, 04:51:26 PM »
Anyone figured out a way to connect the low beam to a switched source that comes on with the engine running?
2014 S1000R Premium White
Akra GP Slip On|Ohlins Damper|Ermax pan|Tecbike CAT|Bestem Fender|V-stream screen|Wunderlich Seat|360+R&G LED signals|R&G+Puig Protection
2012 S1000RR Premium Motorsport
Brocks CT Full System|GPR Damper|Elka Stg3|Sato rearsets|Bestem Cowl|Sargent Seat|Puig Screen|Woodcraft+GB protection|MD signals
H&B panniers on both
Offline amesser325
  • City / Town: Bloomington
« Reply #522 on: August 15, 2018, 05:05:20 PM »
*Originally Posted by Shasta McNasty [+]
I have been trying to figure out a purely "software" fix for this issue for a long time, but so far without success.  I have been able to do some stuff with ISTA/P (a maintenance and software "coding" tool for BMW cars and bikes) but not that.
Can you explain a bit more about what didn't work with ISTA+? I have a rather new dataset, but still not new enough to cover my 2017 build, so I get an 'unrecognized' or similar error.
What I mean to ask, I suppose, is can you drill down into the menus but just can't see where the US lighting is an option in the light module? All my experience in coding is with my 07 530iT car via NCS Expert/Dummy so the programming side of ISTA+ is new to me.
It just seems like this should be a coding thing, based on the other things I've seen in their car programming.
Thanks,
Andy
17 S1000R
07 530iT 6MT
Offline Shasta McNasty
  • City / Town: Northville, MI
« Reply #523 on: August 30, 2018, 10:06:44 PM »
*Originally Posted by amesser325 [+]
Thanks,
Andy
17 S1000R
07 530iT 6MT
Yeah, I can't access any "coding" functions at all in ISTA+ or NCS Expert.  Only "service" functions like would be done at a dealer's service department.  Lighting mode would most likely be coding, not service, as you guessed.
We can manage coding on cars but not the bike.  It's been a while since I last tried, maybe the latest .dat files are better.  Honestly it's been so long I forget the actual error.
What version are you on?
« Last Edit: August 30, 2018, 10:10:59 PM by Shasta McNasty »
Offline amesser325
« Reply #524 on: August 31, 2018, 02:52:00 AM »
I'm running ISTA+ v4.09 and V63.0 DATEN files from around Jan 2018 (or at least when I downloaded them). WAG but since the daten files didn't have a K47 reference I used the K001, which are at least referenced in the I-Level shown on the main vehicle info page of ISTA+
I do get a ignition not found reference, not sure if that's code for low battery or some other weird issue.
My next attempt will be to connect via NCS rather than ISTA. Seems as though the programming and module language hasn't kept up with cars. I suppose since there's only 4 modules interaction is a bit easier to leave well enough alone.
Andy
17 S1000R
« Reply #525 on: September 20, 2018, 11:55:05 PM »
Pro-tip that I haven't seen on this thread yet (although I might have missed it in the 53 pages...):
Some H7 LED (and maybe HID too) bulbs have a separate mounting flange, where the bulb/fan assembly twist-locks in.  If yours are like this, take advantage of it!  Separate the flange and install that first.  It will be much easier to fasten the bail (clamp) on the flange, without the bulb and fan in the way!   :046:
Then you can just twist-lock the new bulb into the flange, kind of like the high beam.  Way easier than doing the bail blind and fighting it around the fan!
Online CrazyBiker
  • Bike: S1R, S1RR
« Reply #526 on: September 21, 2018, 01:12:03 AM »
Anyone found a switched powersource yet that turns on with the motor?
« Reply #527 on: September 21, 2018, 06:02:27 AM »
*Originally Posted by CrazyBiker [+]
Nope
« Reply #528 on: September 24, 2018, 01:55:29 AM »
Wow, I did both the LED mod and the "keep the dang low beam on" mod--what a difference.  Should have done it long ago--especially the low-beam mod!  If you're on the fence,do it.
I think I have to play a bit with headlight aim.  Low beam seems good but the high beam is way too high.  I see a lot of others reporting the same thing though.
Offline Circus
  • Bike: S1000R, Red
  • City / Town: San Diego
« Reply #529 on: January 29, 2019, 03:21:24 AM »
A little perplexed here.  I purchased the OA plug from BMW for the right side (part number 83300413585).  I then connected the OA plug #1 (ground) and #3 (+12V) to an H7 female plug.  I confirmed continuity.
Key on =  0.85V on the H7 plug.
Engine running = 1V and stays at 1V.
About 15 seconds after I turn the bike off and remove the key = 12.5V
60 second mark at which point it goes to 0V.
Under none of these conditions does the 36W LED H7 turn on.  I connected the LED H7 to a car battery and it was like staring into the sun, so the LED H7 is working.
Any advice?
Only two kinds of people in the world . . . women and children.
