Author Topic: Where is a 12v outlet on the S1000r?  (Read 15808 times)
#30
Offline biker_4_life
  • Bike: S1000R 2017
  • Country: hr
Re: Where is a 12v outlet on the S1000r?
Reply #30 on: May 14, 2021, 12:06:58 PM
 :460:
*Originally Posted by miles [+]
My bike has powered various iPhones of mine since 2014 with zero problems.
 :062: :062: :062:
#31
  • Bike: S1000R 2017
  • Country: hr
Reply #31 on: June 09, 2021, 08:19:31 PM
Gents,
I need some help, I have fitted canbus connector as recommended P/N from above, and solder wires as found in one youtube vid.
Then tested and was charging but today when needed it as phone was dead no way to charge.
When I plug in it charges for a 25 sec and that is it.
Any Idea what is wrong.
#32
  • Bike: S1000R 2017
  • Country: hr
Reply #32 on: June 10, 2021, 06:34:43 PM
OK, I have done some more researching.
When I connect phone it is showing charging but actually no charging is happening battery power not going up, low power I assume.
As said I used connector P/N 83 300 0 413 585.
As seen one one youtube video that on this cable wire marked No1 is negative No2 obsolete and No3 Positive.
This is how i had it connected.
Decided to disconnect and removed some insulation from all wires and used multi-meter and measured 12V DC between 2 and 1 meaning 2 is + as when having black black on 2 and red on 1 showing -12V.
I have tried to connect like that but could not manage to charge the phone no power at all.
Now during this process i think i have f up mine USB cable as was sticking probes inside trying to measure something. Newer mind new on on order. Now need to wait for it and then connect to 2 and 1.
If anyone thinks I am doing something wrong please let me know.
#33
  • Bike: S1000R 2017
  • Country: hr
Reply #33 on: June 10, 2021, 08:43:30 PM
Ok so I have problem with leaving things alone.
I have riged up a old USB cable in order to do some measurements and it is giving out 8V DC on USB output while connected as above 2 Positive and ! negative and same with 3 as Negative.
But problem is it is not charging phone but speaker yes.
So still to continue looking for Issue.
#34
Offline bayank
  • Bike: 2018 S1000r
  • City / Town: NJ
Reply #34 on: June 11, 2021, 02:27:08 PM
I think your problem is the actual USB charger, it is not supplying enough amps. even though the bike socket can support 12v @5A (12*5 = 60 watts power), the USB charger that converts 12v to 5v can maybe only support up to 1.5 A (5*1.5 = 7.5 watts power). All the newer fancy iphones and samsungs that support USB C charging are capable of much higher power, and they need it, or else your battery will continue to drain even when plugged in to a charger that cannot deliver enough power. Look into getting a higher amp USB charger, the good ones have usb type C ports and can deliver much more than 2 amps.
#35
  • Bike: S1000R 2017
  • Country: hr
Reply #35 on: June 11, 2021, 09:16:19 PM
Ok, stupid me.
So I have spent some time trouble shooting.
I found that fuse was blow that is why I didn't got any voltage between canbus wires 1 and 3.
After that I was getting 12v between them two.
But phone was not charging.
Then I decided to put original converter from usb charger that I removed from loop as suggested back in the loop and it is working spectacular.
Happy as a Larry now.
Thanks for all help
