Author Lithium Battery on trickle charge??  (Read 12475 times)
  • Offline Johns1000r   gb
    • S1000R Member  ‐    78
    Offline Johns1000r
    • Bike: BMW S1000R SPORT
    • City / Town: Leeds
    on: October 15, 2023, 08:41:25 pm
    Hi, my S1000R has the lithium battery fitted. My question is, is it safe to leave the bike on trickle charge while not in use. This could be for weeks at a time. Thereís a lot of horror stories online about these lithium batteries exploding when on charge (mostly E bikes and E Scooters ) . Am I been paranoid or should I just put it on charge and forget about it?
    Thanks for any replies
  • Offline leomaxi   it
    • S1000R Member  ‐    87
    Offline leomaxi
    • Bike: Bmw S1000R 2020
    • City / Town: Como
    • Country: it
    Re: Lithium Battery on trickle charge??
    Reply #1 on: October 16, 2023, 02:10:10 pm
    Hi, since I have the S1000R 2021 with lithium battery, I only use Optimate chargers and I have no problems, I connect in mid-December and disconnect in mid-March. This is the model I have:
    Optimate Battery Charger: Optimate Lithium 12V/5A ‎TM291, the lithium ones go down very slowly, they are not like the acid or gel ones.... so they are not affected for two weeks
    • #2
    Offline Johns1000r
    Reply #2 on: October 16, 2023, 04:57:17 pm
    Mine too is the Optimate charger, the one specific for lithium batteryís . Iím sure they are designed to be plugged in and forgot about otherwise whatís the point in having a battery charger. I know you canít use a normal battery charger on a lithium battery and vice versa I imagine. I wonder if these e bike and e scooter fires are due to the wrong charger been usedÖÖ..
    Offline leomaxi
    • City / Town: Como
    • Country: it
    Reply #3 on: October 17, 2023, 09:04:24 am
    " I wonder if these e bike and e scooter fires are due to the wrong charger been usedÖÖ"
    Yes
  • Offline john.oldfield.uk   gb
    • S1000R Member  ‐    80
    • Bike: 2017 Gen 2
    • City / Town: Warrington
    Reply #4 on: October 17, 2023, 09:45:24 am
    if its a good quality charger and defined suitable for Lithium batteries then itll be fine.
    If you really worry then set a phone reminder and only charge every 1/2 weeks, but keep an eye on that voltage drop.
    If you dont mind resetting your clock / effort to lift seat and unplug then maybe even disconnect it fully?
    Depending on the battery type , there are different discharge / cycle rules.  For Li deep or full discharge is really bad and will lead to reduced life or replacement.
    My bike 2017 is still on an old type battery.
    It depends on the current draw of your bike how much this will happen (should be negligible but often its not)
    Offline leomaxi
    • City / Town: Como
    • Country: it
    Reply #5 on: October 17, 2023, 09:52:23 am
    I have been using the lithium battery maintainer since December 2021 and use it for 4-5 continuous months. And so far never any problems, the Optimates are the best but they cost... And above all once charged, it only does maintenance, precisely because the lithium ones have much less loss than the standard ones
    • #6
    Offline Johns1000r
    Reply #6 on: October 17, 2023, 05:44:56 pm
    Iíve got the connector bit connected direct to the battery and poking into the space under the passenger seat so no major problem charging it up. You guys have put my mind at ease so Iíll just plug it in and forget about it. Like I said I use a dedicated lithium battery charger and is Optimate which Iím assuming is a quality brand  I also have a Ctek battery charger that does lithium and lead acid batteries that I use on my car. It does have a button that you have to press to change the battery type though. Thanks for all your replies
  • Offline Overdraft   ca
    • S1000R Junior  ‐    8
    Offline Overdraft
    • Bike: 2023 S1000R
    • City / Town: Victoria
    Reply #7 on: February 07, 2024, 11:24:14 pm
    Sorry to revive an old thread, but isn't half the point of Li batteries that they don't lose charge in any practical way?
    Sure, I got a lithium battery because it's so light and "I really notice how much more flickable the bike is" or some such coffee shop flex, but the REAL reason is because I could leave it unattended all winter and it's still got all the cranking amps I need when I dust it off in the spring...
    I had a Li electric outboard on my sailboat and I left it for almost two years and it was still at 75% charge!
    • #8
    Offline Johns1000r
    Reply #8 on: February 08, 2024, 06:18:57 am
    Yeah they last much much longer than normal batteries but I read somewhere that if you leave the security alarm on the battery will be flat in 2 weeks. When my bike is on charge the alarm is also on. No issues so far
