Author Left switchgear not working  (Read 3650 times)
  • Offline Kernowk27   gb
    • S1000R Junior  ‐    7
    Offline Kernowk27
    on: May 11, 2023, 02:52:54 pm
    Left switch gear decided to intermittently give up again. Hazards stuck on. Disconnected the battery. No joy.
    Anyone had any faults remedied or fixes for this? Because itís intermittent itís rather annoying to fix. Gen 3.  :828:
    • S1000R Junior  ‐    7
    • #1
    Offline Kernowk27
    Re: Left switchgear not working
    Reply #1 on: May 12, 2023, 01:43:57 pm
    • S1000R Junior  ‐    7
    • #2
    Offline Kernowk27
    Reply #2 on: May 12, 2023, 01:47:00 pm
    So I took the plastic cover off, unscrewing the two size 7 torx or spline drives, I clipped the plastic cover and carefully removed. One of the cables had been pulled from the female socket, the lower one with 3 wires inside it. I replaced the cover and pushed it back in firmly but had to remove the clutch lever for access. Put it all back and it works. And the Ďlow battery in key fobí message has gone too. Result.
