Author Constant buzzing under tank - TPS/Throttle Bodies?  (Read 3600 times)
  • Offline GreyR   gb
    • S1000R Junior  ‐    2
    Offline GreyR
    • Bike: '19 S1000RS Grey
    • City / Town: England
    on: March 02, 2023, 02:11:48 pm
    Hi all,
    I've got a 19-plate S1000R Sport with ~4k miles.
    I've fitted a decat link pipe which looks great and sounds even better.. along with a servo buddy. However since fitting (or maybe before and I just hadn't noticed) there's been a constant electric buzzing under the tank with the ignition switched on.
    The noise fluctuates when twisting the throttle. I've done a small amount of research and it looks like could be that the throttle bodies need resetting - I was hoping someone could confirm. Also, if anyone is in Norfolk who has a GS-911 or ODBII adapter compatible with Motoscan who could help me out, that would be appreciated.
    I've attached a video, hopefully linking to another site is allowed!
    https://streamable.com/oxdjif
    Thanks!
  • Offline GreyR   gb
    • S1000R Junior  ‐    2
    • #1
    Offline GreyR
    Re: Constant buzzing under tank - TPS/Throttle Bodies?
    Reply #1 on: March 08, 2023, 11:24:47 am
    Just an update.
    Have reset the adaptations for both throttle valves and throttle. Still buzzing.
    Anyone got any ideas?
  • Offline Enzio   za
    • S1000R Pro  ‐    289
    Offline Enzio
    • City / Town: Pretoria
    Reply #2 on: March 23, 2023, 11:19:20 am
    The DDC also makes a buzzing noise.
    If you have the ignition ON and change DDC settings you will hear the pitch of the noise also change.
    Unless it is making strange noises with the engine running or throwing errors it shouldn't likely be an issue.
