Author Topic: Suspension switch left handle bar switchgear  (Read 431 times)
Offline Scrummage
  • City / Town: Leeds
on: May 24, 2022, 10:22:31 PM
Hello. I don’t know if this is the right section. But here goes. I have a 2016 s1000r and it doesn’t have the shock absorber symbol on the left handlebar switch gear. It’s just blank. I obviously have the electronic suspension ie road dynamic etc. would just like to No if I bought the left switchgear with suspension switch on it. Is it already programmed into the bike or is it a firmware update. Thanks for any help.
Re: Suspension switch left handle bar switchgear
Reply #1 on: May 24, 2022, 11:11:30 PM
Is it obvious you have Electronic Suspension?? I would assume you would have the correct switch if that was the case. Tell-tale signs are gold coloured forks and there should be a wire coming out of the top of the left hand(clutch) fork.
Offline Scrummage
Reply #2 on: May 24, 2022, 11:23:56 PM
Yes that is correct. I have the wire and gold forks. That’s why I can’t understand it.
Reply #3 on: May 25, 2022, 02:23:24 AM
given that, the only explanation that I can come up with is a prior owner replaced the left switch with the wrong unit.  :005:
There are sites out there that will tell you the 'build' if you enter your VIN. Other than that I think your best option is a dealer to see what they think.
Offline Scrummage
Reply #4 on: May 25, 2022, 01:22:15 PM
Yes thanks found the spec out and it hasn’t got the esa installed. Thanks
