Author S1000rr stalling  (Read 5285 times)
  • Offline boomtheroom   nz
    • S1000R Junior  ‐    4
    Offline boomtheroom
    • Bike: 2010 s1000rr
    • Country: nz
    S1000rr stalling
    on: April 27, 2022, 08:05:09 am
    Hey Guys
    I know I have a s1000rr and not a s1000r but i imagine they are basically the same bike.. as i have tried on all the s1000r forums..maybe u can help me here?
    my bike has started stalling randomly as i come to a stop.. it will start up straight after  but seems to do it when clutch in at low revs , see videos.... :006:
    Cheers!
  • Offline Hamburg   gb
    • S1000R Pro  ‐    419
    Offline Hamburg
    • City / Town: Oxford
    Re: S1000rr stalling
    Reply #1 on: April 27, 2022, 12:14:17 pm
    If you are using aftermarket levers this can be caused by the small tab under the clutch lever either being damaged or not engaging properly
    • S1000R Junior  ‐    4
    • #2
    Offline boomtheroom
    • Country: nz
    Reply #2 on: April 27, 2022, 12:34:56 pm
    tab is fine.. levers are bmw factory option.. but how would the switch effect the bike stalling anyway. Doesn't it only effect the quickshifter or starting the bike in gear?
    cheers!
  • Offline miles   us
    • S1000R Grand Master  ‐    2304
    • Bike: A baby blue one
    Reply #3 on: April 27, 2022, 02:44:28 pm
    I don't have any advice for you, but I just have to say that I love the Acid Green Metallic. That was the color I chose for my RR, too. One of the reasons I loved it was that no Japanese bike would ever have been painted that shade.
  • Offline Zig Zag   us
    • S1000R Master  ‐    545
    Offline Zig Zag
    • Bike: 2016 Black Storm
    • City / Town: Virginia
    Reply #4 on: April 27, 2022, 05:13:29 pm
    Itís acting like the problem might be gas. Maybe obstructed fuel filter or possible vapor lock? Sorry, just a stab in the darkÖ
  • Offline Hooligan   ca
    • S1000R Master  ‐    521
    • Bike: 18 S1KR
    Reply #5 on: April 28, 2022, 01:22:41 pm
    Stand sensor issue ??? just a thought.
    • S1000R Junior  ‐    4
    • #6
    Offline boomtheroom
    • Country: nz
    Reply #6 on: April 28, 2022, 07:54:56 pm
    *Originally Posted by Hooligan [+]
    nah don't think so .. had the bike up on chock stand while running and messed around with the stand.. didn't fault... leaning towards clutch switch  because i always have the clutch in changing down when it happens.. but dont understand how the clutch switch would stall the bike....Prevent it from starting in gear, yes...stop quick shifter from working, yes ... but stalling? anyone enlighten me?
  • Offline rogracer   us
    • S1000R Pro  ‐    193
    Offline rogracer
    • City / Town: Orlando, Florida
    Reply #7 on: May 09, 2022, 01:24:32 pm
    I couldn't tell exactly from the video but it seemed like you may be chopping the throttle at the same time you're pulling in the clutch lever.  That can cause the rpm to drop below target idle speed and cause a bike to stall.
    Last Edit: May 09, 2022, 01:25:08 pm by rogracer
  • Offline ICW   au
    • S1000R Junior  ‐    6
    Offline ICW
    • ICW
    • City / Town: North Warrandyte
    Reply #8 on: May 20, 2022, 08:52:56 am
    Hi,
    I have the same issue.  My bike is a S1000R 2021 model build date i.e., exit from the plant was Jan 3 2021.
    Problem is, sometimes when I am rolling to a stop the engine completely cuts out in a manner like hitting the "stop" switch, it's not a stall just total electronic power to the engine is lost.  Why, cut out?  I hadn't engaged the "stop" switch and as I was rolling foward so then I tried to release the clutch to perform a rolling start the outcome was engine didn't fire! (Like you have engaged the "stop" switch) Now as I was still rolling (at say 3-5kmh) I engaged the starter switch with the clutch disengaged (lever in) and it immediately started up, I then stopped and performed a turn.  Given this, it appears a computer electrical issue or maybe something else (see my post script).  Any further ideas as it has happened five times and spooky when lane filtering.
    Cheers
    ICW
    PS: I will check that clutch lever as I know from earlier S1000R (2017) if the bolt holding your clutch lever together is in any way loose you have issues with the micro switches that control clutch and QS.
    • Bike: 18 S1KR
    Reply #9 on: May 20, 2022, 12:32:05 pm
    *Originally Posted by ICW [+]
    Hi,
    Cheers
    ICW
    Sounds nothing less than life threatening. I would take it back to the dealer for warranty claim.
