Author In-situ Battery charging  (Read 5008 times)
  • Offline J90   ie
    • S1000R Junior  ‐    2
    Offline J90
    • City / Town: New Ross
    • Country: ie
    on: August 27, 2021, 02:47:49 pm
    Hi,
    Can anyone advice me which is the best way of in-situ battery charging?
    I had thought of installing a DIN socket to one of the the standard bmw oa connection with an Optimate 4 CAN-bus but the dealer said ‘ never charge using a DIN socket as it switches on instruments/ ignition, activates it somehow so when the battery has finished charging the ignition or something is still on and drains the battery ….. or something along those lines’.
    Alternatively I could connect the Optimate directly to the battery but my understanding is that the charger reacts differently this way.
    I’d greatly appreciate you help.
    Joe
  • Offline jcurl_007   us
    • S1000R Member  ‐    58
    Offline jcurl_007
    • City / Town: WI, USA
    Re: In-situ Battery charging
    Reply #1 on: August 27, 2021, 03:54:18 pm
    Connect straight to battery. Charger does not act differently.
  • Offline Hamburg   gb
    • S1000R Pro  ‐    419
    Offline Hamburg
    • City / Town: Oxford
    Reply #2 on: August 27, 2021, 03:58:48 pm
    ^^ this
  • Offline J90   ie
    • S1000R Junior  ‐    2
    • #3
    Offline J90
    • Country: ie
    Reply #3 on: August 27, 2021, 08:46:26 pm
    Thanks guys,
    my impression from Optimate was that the charger behaved differently when it was connected to a DIN can-bus connector rather than directly to the battery?
    Joe
    • S1000R Pro  ‐    419
    Offline Hamburg
    Reply #4 on: August 27, 2021, 10:32:05 pm
    Unlike some other BMW bikes the S1000R doesn’t have a din aux socket, so most of us just use a regular charger, using a pig tail lead directly connected to the battery.
    If you have an Optimate for use with BMW canbus, just switch it over to the normal setting and use a direct connection to the battery
  • Offline beech   us
    • S1000R Master  ‐    806
    • Bike: S1000R, K1300Sx2
    Reply #5 on: April 04, 2022, 05:45:09 am
    Hamburg has the right plan. Not everyone has an Optimate with the CAN bus system selection. Mine does not. I have a DIN Socket directly wired to the battery via a 15 amp fuse in line. I have this so I can also use a heated vest or a mini air pump for flats. This or a pig tail SAE socket is the first thing any of these bikes need.
  • Offline john.oldfield.uk   gb
    • S1000R Member  ‐    80
    • Bike: 2017 Gen 2
    • City / Town: Warrington
    Reply #6 on: April 04, 2022, 02:22:47 pm
    i went this direction with a cable socket to charger. (my only concern is theres no inline fuse between battery and connector but you could easily add one.
    http://johnoldfield.blogspot.com/2022/01/draft-install-ctek-battery-charger.html
  • Offline beech   us
    Reply #7 on: April 04, 2022, 05:06:26 pm
    The no fuse should be ok unless the positive lead rubs through to the frame. Someone at the charger company was saving money. Most motorcycle shops sell the pigtail with a fuse in it and at some point I suggest you use one of those. Then you will be safe from normal wear and can use the circuit for other needs. (like a heated jacket liner)
